BirdmanLS1
02-28-2006, 02:11 PM
ok... so what is the best rpm to shift at when racing an m6 ls1? Should you redline every shift, or are there peaks that you should shift at? I have always wanted to know, just want to be a better driver. Thanks for info in advance...
BLKWS.6
03-04-2006, 03:45 AM
Take your dyno chart, shift where the next gear will fall in the fattest part of your tq peak. If not, get as close to it as possible, i dunno, thats just my humble advice. Like on a stock 5.0, anyone shifting past 5K or so is being an idiot and losing ET. pretty much same for the 4.6's but not QUITE as bad.
hurley_21_07
03-04-2006, 02:51 PM
Try the Racer's Lounge.
Dan
