Lock Up Solenoid
Old 02-28-2006, 04:30 PM
formulajunky's Avatar
Default Lock Up Solenoid
Yeah i had a ses light at the end of last year, and was told that is why my tc wasn't locking up. Well I was told I had to replace the "lock up solenoid" but i can't seem to find one for a 4l60e, any advice would be nice on where to get this or If this can be the problem
Old 02-28-2006, 05:08 PM
Anyone?? ttttt
Old 02-28-2006, 07:17 PM
FLT
FLT's Avatar
OEM GM # 24230340. Hope this helps.
Old 02-28-2006, 07:20 PM
FLT
FLT's Avatar
GM # 24230340. Hope this helps!!!
Old 03-01-2006, 10:15 PM
2001 firehawk's Avatar
Is that what is called the b solenoid ? I just got a code that said b solenoid had a problem. Is there a place that sells a performance one?
Old 03-01-2006, 10:22 PM
FLT
FLT's Avatar
No the b solenoid is a shift solenoid located in the rear of the valve body. I've never heard of hp shift solenoids. I only use OE ones.
Old 03-02-2006, 05:10 PM
would this be a part that would need replacing at about 54000 miles? Would it probably just need cleaned. Sorry to steal the thread, but I need some info. You know how much and how hard to changr this part? All info much appreciated
Old 03-03-2006, 12:20 PM
badcompanyvpws6's Avatar
I had the same problem. The code read "shift solenoid circuit b stuck on"
Needless to say...my trans blew two weeks later and i got it "re-inforced" I'd get that taken care of asap. Good luck.
Old 03-03-2006, 12:24 PM
What was your mileage on the car. Where are you located? Lots of mods or not? Thanks for the tip it is at the shop right now.
Old 03-03-2006, 06:34 PM
Q
Q's Avatar
Question, do you builders replace the shift solenoids, epc solendoid, and the lock up solenoids when you rebuild a transmission?
TIA
Old 03-03-2006, 07:00 PM
chipz's Avatar
I would replace all of the electronics on the valve body.
Old 03-03-2006, 10:38 PM
Q
Q's Avatar
good deal..thanks for the info.
Old 03-03-2006, 11:49 PM
01_ram-air's Avatar
I just threw the shift solenoid code also. I run it at the track, spray it, and have a 4000 stall converter. It's fairly cheap and easy to replace. I did notice that the converter is locking up much better now too. Hope this helps. Oh, 67000 on the clock.
Old 03-04-2006, 01:00 AM
Did it start running very weird,slipping and bogging way down when it happened?
Old 03-04-2006, 01:48 AM
01_ram-air's Avatar
converter didn't want to lock up like normal. Didn't want to downshift.
Old 03-04-2006, 10:37 AM
mines doing alot of weird stuff like not wanting to go in 3rd or 4th.Slipping,etc
Old 03-05-2006, 05:20 PM
Red Heartbeat's Avatar
It seems the 2001 and 2002 PCMs get confused with high RPM stall convertors. Delete/Remove the tests in the PCM for codes P0757 and P0751.
