Need a little Help
Need a little Help
hey guys im removing my tranny to take to the tranny shop.Does any one know how to remove the trans lines from the tranny looks like plastic clips around it or something..........Next the bad part is i stripped a tourque converter bolt its one of those hex bits any body got a way i can remove it easier its stripped or can i remove the tranny and leave the torque converter in and pull the trann and get it out later??????
the lines are held in with c clips under the plactic you are talking about. slide the plastic down the line and get a seal pick or tiny screw driver to remove the c clips and pull the line out. As far as the TC bolts get grade 8 replacement bolts, I forget what size they are, from your local hardware store. They will work fine and are regular bolts instead of hex heads. hope this helps
