Does this sound like a winner to you ??
Im getting my Pro turbo systems kit in 2 weeks now and this is the combo what do you think I should do different.
All the hot parts
Precision 76 gts-h turbo
huge front mount intercooler
38mm turbosmart wastegate
50mm tial bov
366 cid iron block
stock crank
Oliver billit rods
Diamond pistons 9:1
Patriot s3 ls6 style heads 2.08 1.60 64cc
Futral f-4 cam 226,226-575,575 on 114
Edelbrock victor jr intake with elbow and stock ported throttle body
4l60 I know it will be replaced later
4200 stall yank pye
stock rear for now 3.23 gears.
Car wieghs 3500 race weight
cuts 1.52 60's at 11.05 @ 123 now with the above combo except stock short block
I plan on running 10 psi for now then when the rest of the car is built I will push it to 20+ psi
So what do you think this thing is capable of and have I missed anything
Thanks for all the help for you FI guys steering me along the way . I hope this thing goes single digits.
All the hot parts
50mm tial bov
366 cid iron block
stock crank
Oliver billit rods
Diamond pistons 9:1
4200 stall yank pye
SSU Moderator
Personally, I'd do the following.
-Dart 225cc heads (with ARP studs)
-I don't have a calculator handy, but overlap can be helpful in a turbo car. INTMD8 knows his stuff, I'd talk to him or W2W about a cam. I personally don't like off the shelf cams or really any cam over like 224/224 for a turbo car. Boost is going to give you power...plus I like quiet cars.
-Get an elbow that puts the TB in the stock location. Plus, a ported TB isnt really going to do much IMO. Unless its already ported...just leave it and save time/$.
-I don't think you'll need more than like a 3400-3600 stall. 3.23's will be fine.
-You could even go lower with compression and let the timing do the work. No personal experience here, just seeing what others have done and commented about.
I like A2W coolers because I don't like holes in the bumpers, but everything else looks good to go.
I would agree with everything you said except I have had all these parts on the car and running now for one year. Except for the new short block and the turbo kit. I agree this is probably not the best way to build a turbo car but its what Ive got to work with. I am on a tight budget and this will have to do for now. I will be doing things as the money allows . I know all of you are going to say turbos and budgets dont mix and I tend to agree. I already have about 15000 in this car as is just getting the car up and running for the turbo .
On a side not does anyone know the best deal on 72# RC injectors and where to get them. I cant find them on any of the sponsor sites.
I would have gotten a bigger wastegate also but pro turbo and the owner of forcedinductions.com said it would be ok up to 1000 horses. I dont believe it but thats what they told me, and the piping is set up for that wastegate so for now thats what Ill run and lter ill upgrade to atmosphere dump and bigger mm. As far as head deck goes I can live with the fact that I will push a little water at the track under high boost. I had to deal with it with my old 346 and 325 shot of spray. It would only lift the heads on the dyno and just a little at the end of the track. The iron block should help a little over my old aluminium one.
Like I said once more money comes I will try to get better parts but I already have these so I will just reuse them on this motor for now. The trans is the biggest of my problems for now ,its about gone and its going to cost $3000 for a th400 setup.
All the hot parts
50mm tial bov
366 cid iron block
stock crank
Oliver billit rods
Diamond pistons 9:1
4200 stall yank pye
All the hot parts
50mm tial bov
366 cid iron block
stock crank
Oliver billit rods
Diamond pistons 9:1
4200 stall yank pye
Very good choice on the set-up, I think you'll be really happy with it!
Later,
Dave
my .02
converter is way to big, unless you plan to spin it beyond 7500 rpm.
Cam will work, i have something similar in my truck
the 76 will be hard pressed if you plan to push it close to 20 psi. You'll have no problems with the heads at that level, just stud the motor and keep good fuel in it.
gate size is a function of LOWEST boost setting, has nothing to do with power output. Max power = closed wastegate.
Will the 72#ers be enough ?? Should I try to get 8.5:1 pistons in stead of 9.0:1?
How much power would I pick up if I got a turbo spec. cam? Should I go with a th400 with transbrake, or do a powerglide with transbrake. I will get the 9 inch after a while too what gears??
