What tire size?
What tire sizes would you get?
I have 4 18x9"s and was wondering what tire sizes you guys recommend? I was thinking 275/35 up front and 285/35 out back. I would like a slight racked look and as big of a tire out back as I can fit safely. I would like to widen the back two an 1" so I can put a 295 or 305 out back but I think that will be later on.
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
dunno if u've looked at the sticky but if not then peruse it.
I ran 275/35s up front and 285/35 out back when i had 18x9.5in Y2Ks on my SS. You could probably fit a 295 out back but its probably not recommended
kinda like doing 315/35 17s on 9 or 9.5 wide in rims.
hope that helps
hope that helps
