anybody g-tech w/turbo car??
has anybody else used a g-tech meter like the older one, on there turbo car, and want to admit what the times were?
I've heard of guys throwing them away case they were unhappy w/the results and sometimes they just dont work on some cars..., but I tried last night on street tires and had to feather the throttle like crazy 1st and part of 2nd, but I got a 12.6 @ 121, does that sound slow for street tires and 5.5lbs of boost on an otherwise stock ls1 M6 vette(all exhaust going through stock 99 mufflers, mcleod twin disc w/steel flywheel, dte brace, and hardened ouput shaft only other mods), I'm thinking I've got about 440 to the wheels, my afr was 10.8-11.0 so it was on the safe side.... in the past on other cars I've picked up .6 from drag radials alone... my mph is allways on the high side w/this car, I watched the video and the speedo is climbing like crazy above 60.... I know there are some 10.9 sec. cars running 121mph, and most about 11.5 at that speed... any others in the same boat??
1 Post
To gtruly accurate times you need to ensure the G-tech is calibrated, to include the accurate weight of your vehicle with you in it. It will skew the numbers otherwise. 121mph is probably a bit high. 115-118 on a stock car w/ 5lbs seems more believable. Noever know, could be. The wheelspin will artificially increase your mph in the 1/4 too and of course decrease your ET.
With a 5lb turbo on a stock LS1, I'd guess you're looking around 400RWHP, which is about 465 or so at the crank. Heck, I'm probably only making 450 or so RWHP and have LT's, a cam, and the turbo.
Originally Posted by Schantin
...To gtruly accurate times you need to ensure the G-tech is calibrated, to include the accurate weight of your vehicle with you in it. It will skew the numbers otherwise. 121mph is probably a bit high. 115-118 on a stock car w/ 5lbs seems more believable. Noever know, could be. The wheelspin will artificially increase your mph in the 1/4 too and of course decrease your ET.
Since the accelerometer in the unit determines your actual acceleration rate, the times and speeds will be accurate regardless of wheel spin and regardless of what weight you vehicle really is.
I've heard really good things about the g-tech's accuracy (even the old ones) with most people claiming it's just a little bit off and consistently so (which makes it good for quantifying the benefits of performance mods.)
I used to have the "old" little black one, and I now use one of their "pro" models from about three years ago. For their newer models, I'd say accuracy is OK, and precision is excellent.
jyeager, you are partially correct. For pure acceleration numbers, the unit does not require vehicle weight. You will still pay for poor launches and wheelspin, however, as the unit detects that first bump of acceleration and starts timing you immediately... and if you're spinning after that, well, your times will suffer.
The current models that allow connection to PC and dumping data are most useful, IMO, for doing 2nd gear "dyno" runs. This requires accurate weight for the car (I even correct for how much fuel is in the tank). You start off, run 1st gear to about 4k, shift to 2nd, and roll the throttle evenly to WOT. If you're on a level road with not much wind, successive runs in both directions will generate HP/TQ vs. rpm curves that are virtually identical. So the meter is most useful for showing real-world acceleration (fully-loaded motor) for you to use in measuring the impact of mods on the same car. I wouldn't waste too much time trying to compare your numbers to other cars, unless you can run the tests the same way.
*edit* So anyway, I'm thinking that for turbo cars this might actually allow you to tune under actual engine/drivetrain loading, and (when used with a logging wideband) help you get the most out of your system. Might also be useful for eBoost2 users.
i also have the "pro" model which is very accurate. with my 99Z(before i wrecked it while playing around w/ the g-tech believe it or not) I was within 1tenth and 1mph than my actual time/mph at the track. Ran the track time then g-tech time on the street roughly 1 week apart. Used it on the SS to but havent ran the SS at the track yet so cant compare
1 Post
