4.060 bore on an lt1...need opinions
Old 03-01-2006, 11:19 PM
Sixspeed042's Avatar
Default 4.060 bore on an lt1...need opinions
looks as if it needs bored again. it's either 4.060 or new block. what are your thoughts? if new block ,i need one asap
Old 03-02-2006, 12:09 AM
TwoFast4Lv's Avatar
We have one running on the streets hitting 450RWHP
Old 03-02-2006, 12:25 AM
Flores96TA's Avatar
You r pushing it but can be done. Got some blocks if you need some .
96 T/A LT1
Poor Man Mods
Stock heads cam
W/juice 150shot
Old 03-02-2006, 12:57 AM
buffman's Avatar
You can go pretty big on this LTX block
Old 03-02-2006, 01:10 AM
Steve40th's Avatar
Why you gotta tease with that picture of the aluminum LT1.
Also, there is quite a few LT1's running 60 over. It will run a tad hotter, water and oil temp. But no biggie.
Old 03-02-2006, 09:06 AM
i have no way to sonic check the block...you think i will be ok?
Old 03-02-2006, 09:46 AM
Moderator
BizZzatch350's Avatar
Why are we going that big a bore just because its the biggest doesnt mean its the best.
Old 03-02-2006, 10:26 AM
because i have no choice, other than to get a new block. read my first post.
Old 03-02-2006, 10:30 AM
Steve40th's Avatar
Can you do a 40 over?
Old 03-02-2006, 11:13 AM
Moderator
I would go out and look for a new block
I'm guessing his block is trashed
Old 03-02-2006, 01:45 PM
slick1851's Avatar
408 Lt1s are pretty bad!
Old 03-02-2006, 01:48 PM
let me clarify... the block was once built before and at a .040 over. the block since then has had some dirt scores but nothing deep. it needs bored again to get proper oil usage and such. it can clean up at 4.045-4.050 but i'd have to get custom pistons made for the block. if i can't get custom pistons, i have to go .060 over and get .060 over pistons. sorry for the confusion.
Old 03-02-2006, 08:37 PM
fastassta's Avatar
I had to go 60 over and mine was fine,no heat issues. My car also sees a 300-400 shot.
Old 03-02-2006, 10:11 PM
did u have it sonic checked or any special machine work? and this was a regular lt1 block?
Old 03-03-2006, 06:43 AM
383LT1S10's Avatar
Speed Pro offers .080" pistons
.060" you will be fine just run a good cooling system.
Old 03-03-2006, 03:33 PM
the block can clean up at .045 but i will need custom pistons. looks like about 800 for pistons, rings and pins for this 4.045 bore. any thoughts?
Old 03-05-2006, 07:57 PM
fastassta's Avatar
no special work on block,and yes it is a stock block.
Old 03-05-2006, 11:09 PM
it's going to cost me 500 more to get custom pistons, but do you think it'll be worth it since i know i wont have cooling issues or bolt caving possibilites?
Old 04-01-2006, 08:07 PM
slowpoke96z28's Avatar
will .060 over run into cylinder wall flexing?
Old 04-01-2006, 11:13 PM
Steve40th's Avatar
No. There are plenty of people running that bore size, and any competent shop will check it for you.
Quick Reply: 4.060 bore on an lt1...need opinions
