whats needed with a 17x11 rims
Old 03-02-2006, 12:51 AM
ls1chris's Avatar
Default whats needed with a 17x11 rims
ok im looking at the Torq Thrust II special from tomz wheels and was curious will i have to do anything special to get them on my car i have the stock 16 inch rims on it now what will i have to do to get them under their. i think the deep dish will look sick thanks guys
Old 03-02-2006, 01:01 AM
99camarosupersport's Avatar
you will need rear spacers ( cheap ), and possibly a hammer but maybe not i didn't but some do. good luck.
Old 03-02-2006, 01:04 AM
Juiced2000SS's Avatar
Well, worst case you will need to pound a bit in the inner fenders and roll the fender lips. Possibly need to trim the bump stops (if you want to lift the car by the body without the wheels hanging) a little. More so if the car is lowered. Then you will benefit greatly from an adjustable PHR. I think some have had trouble with the TT2's rubbing on the front break caliper bracket also. Just get them, we will walk you through it if you need any help when you put them on.
Old 03-02-2006, 01:05 AM
I beg to differ on the spacers, if you get 7-3/4 backspace everything should be fine.
Old 03-02-2006, 01:48 AM
ls1chris's Avatar
thanks guys im goin to order them the end of this week ..so next weekend look out... headers and wheels install to do sounds like a busy weekend lol ill keep you all posted appreciate the help
Old 03-02-2006, 06:03 AM
AbsolutHank's Avatar
TomZWheels has the specific offsets for our cars...you will not need any spacers....at most, you'll have to hammer in the inner fender just a tad.
Old 03-02-2006, 06:21 AM
IMJ
IMJ's Avatar
the only thing i had to do to get my rims to fit was trim the corners of the bump stops a bit. i didnt even have to do the bfh mod....
Old 03-02-2006, 06:21 PM
RrCoX22's Avatar
i will be ordering mine tomar... 3/3
and i have sportlines too... this will be fun i'm sure i will have to do everything in the book next weekend to make these puppys fit
Old 03-02-2006, 10:40 PM
i had to use a spacer for my z06 motorsports, and they are pretty much the same size. not sure the offset, i will check in a few. anyways thats why i suggested the spacer.
Old 03-02-2006, 11:24 PM
MM98's Avatar
The rear offset on the 17x11 TTII's is +46mm, no spacers are needed... I'm lowered with bmr 1" springs & not using the rear spring insolators... I had to do absolutely nothing, bolted them up & haven't had a problem yet... I did however buy an adj rphb to center up the rear some.
Mike
