What would you do?
What would you do?
i know some of you will notice that ive asked alot of questions about what you guys thought what was wrong with my car, but now i wanna know what you guys would do if you were me to my car, its a 93 Z28 A4, 120,000 miles and it has a blown head gasket so im going to be dropping the motor, what should i do since im going to have the motor out of the car, thanks in advance.
well damn that's an easy question to answer...you said you have a blown head gasket, with a sound bottom end....i would install a comp 230/242 114lsa cam, (cmotorsports: TS-230XL) get a set of long tube headers (pacesetter ceramic coated), have the heads rebuild and topped with some comp .600 lift springs (cmotorsports: CC-26918-16) buy a thinner head gasket to raise the compression (higher compression better performance and gas milage) and get it tuned by PCMforless, and your looking at a ~350rwhp car that will get ~25-26mpg on the highway....and i know it's a proven setup because i've did two other LT1's with this combo with those exact results. (one used jethot long tubes, and the other one had a slightly smaller N/A cam in it but with the pacesetter's) Keep your stock injectors, fuel pump, throttle body, intake manifold, heads, and bottom end and still get great numbers. its a low 12, high 11 sec with a good 60' time.
Just cam it. Use a CC305 or equivlant cam. It'll run great and give you an extra 40 rwhp over stock with supporting mods. You can port the heads if you got the cash. I'd at least do a valve job on them.
yeah thats what i was thinking, do a cam and have my heads done, i would also like to make the motor as a good as possible so i wont have to worry about spraying lets say a 150 shot. do u know of any good guys that could pretty much comletely redo my heads?
Originally Posted by urbanhunter44
if you want them ported, www.eportworks.com
Originally Posted by TransAm6383
LLoyd Elliot is the man when it comes to porting heads..he does EXCELLENT work
