how many of you are running an engine girdle???
Old 03-02-2006, 06:46 PM
BLk01SS's Avatar
Question how many of you are running an engine girdle???
Just wondering how many people are running one and if its really needed???
Old 03-02-2006, 07:08 PM
Phate's Avatar
W2W made the girdle that is on my motor.
It really depends what kind of power you are going to be making and what block you are going to be using. I think that for an aluminum motor people probably start to see some movement around the 1000hp level, so it's probably a good idea if that is what you are looking at. On an iron motor ~1200hp is starting to push it without a girdle.
Personally, I think it is cheap insurance on a high dollar motor. If it takes internal stresses off of other parts then it is well worth the money spent...although I wouldn't bother on anything below the 750hp level.
Old 03-02-2006, 07:51 PM
BAD FNZ's Avatar
Excuse my ignorance, but what is an engine girdle?
Old 03-02-2006, 08:04 PM
Richiec77's Avatar
It's a plate that ties all the main caps together on the bottom end. Not really needed too much on the LSx platform due to the 6-bolt mains and deep skirt we use. The power levels above are about where you would start looking to need one.
Old 03-02-2006, 09:02 PM
BAD FNZ's Avatar
Ah ok... so something about 850 or so...?
Old 03-02-2006, 09:24 PM
00turboT/A's Avatar
I agree around 850Hp is where you will need one
Old 03-02-2006, 10:08 PM
427's Avatar
I use the same one as Scott on my 352ci iron block engine. I have seen signs of things moving on gen3 engines in the 1,000hp area.
Does it really need it? I have never ran without one on high hp engines, although I'm sure somebody does.
Kurt
Old 03-02-2006, 10:39 PM
BLk01SS's Avatar
How much do you guys sell one for Kurt? I've seen the ones on ebay but no where else until now.
Old 03-03-2006, 03:38 AM
Z06PSI's Avatar
I got one of the ebay ones and they are very nice pieces....
Old 03-03-2006, 09:35 AM
427's Avatar
The one on e-bay is not the same as our's. The girdle we use would be around 2,000.00 by the time we get it installed on the engine.
Kurt
Old 03-03-2006, 09:39 AM
Tiago's Avatar
Old 03-03-2006, 10:03 AM
smokinHawk's Avatar
Originally Posted by Tiago
when i talked to kurt about it he told me you needed to do some machine work to the block and it ties in with the pan bolts too (if im remembering right)
the whole thing ties in better then the other one.
i didnt think mike and steve were running a girtle on their iron block though.
Old 03-03-2006, 10:27 AM
Phate's Avatar
I am pretty sure that Mike and Steve are running the girdle setup from W2W, although I am not sure if Mike is using it on the CE.
Folks, don't be suprised at the prices...you get what you pay for. When you get something from W2W you can assure that not only is it installed and setup perfectly, but it has also been tested on the dyno. You aren't buying hype...you are buying something that has stood up to real world testing!
Old 03-03-2006, 10:30 AM
98turbls1's Avatar
Wow!!!! how high have these girdles been taken to as far as horsepower???
Old 03-03-2006, 10:35 AM
427's Avatar
The Formula has a girdle on its iron 404 engine, the CE has no girdle on a LS2 6.0 engine.
Kurt
Old 03-03-2006, 11:59 AM
smokinHawk's Avatar
Kurt
oh ok must have misunderstood them, thought they told me they wernt running one, guess i was wrong (on the formula).
Old 03-03-2006, 12:07 PM
mahhddgtp's Avatar
$2000 for a girdle? This one is $525 shipped and I've heard they're pretty good.... You were talking installed though... But still.. It shouldn't be too horrendous of a DIY yourself job if you have a garage/place to drop your engine, should it?
http://www.dmperformance.org/new/Index.html
Old 03-03-2006, 01:10 PM
Phate's Avatar
As far as I understand, the girdle needs to be installed onto the motor when the machine work is being done. It is not just something that you can bolt-on to a shortblock if you want the maximum benefit.
Like everything else, this is a case of you get what you pay for...there are reasons that some things are more expensive then others. There aren't a lot of LSx based motors that are making 1200+hp, but from what I have seen most of the ones that are come from W2W.
This conversation probably isn't relevant to a lot of people, since there are only a handful of people on here that will ever come close to 1000hp. For the people that will, my recommendation would be to go with the people that have done it most and repeatably.
Old 03-03-2006, 01:42 PM
LS1TECH Sponsor
Kevin@W2W's Avatar
Correct, producing the girdle isn't that expensive and we actually produce it in house.
The labor to install it in a correct manner is what pushes the cost way up and is one of the reasons we prefer not to sell it as a retail piece. It takes quite a bit of time as well as knowing what to do.
Old 03-03-2006, 02:05 PM
427's Avatar
Mike and Steve do have the only one that we ever did without steel main caps.
The process is machine the top of the cold rolled steel main caps on a surface grinder to equal all the heights within .0002 on the height of the caps, this is what the girdle will sit on. Then install ARP studs that are made for this girdle(longer length). Install caps and measure from oilpan rail to main caps on 4 corners. Machine oilpan rail of block flat to equalize dimension at all four corners, record dimension of step.
Machine step in girdle to .005 deeper than differential on cap measurment. Install girdle on maincaps (at this point a .005 feeler gage will fit between pan rail and girdle).
install oilpan bolts through girdle to block and torque mains and oilpan bolts.
Align bore main bearing saddles, and hone to factory specs.
Cut o-ring groove in girdle at block interface for .102 buna cord to seal the girdle to lower block surface.
Before final engine assembly install o-ring cord in girdle blockside, lower girdle to pan seals with factory gasket.
Start engine and add BOOST!!!
Kurt
Quick Reply: how many of you are running an engine girdle???
