what PSI do you run in your tires
Old 03-02-2006, 07:18 PM
FireSilverLullaby's Avatar
Default what PSI do you run in your tires
Hey,
What psi do you run in your stock tires at the drag track. What set-up works best for you.
Old 03-02-2006, 07:23 PM
GETGONE's Avatar
I tried playing with pressure and actually got my fastest time @ 32psi on the stock Goodyear F1's. They're about done for so I might drop all the way down to 20psi and try them again. I run 20psi in my MT DR's per MT's recommendation and they hook awesome. MUCH softer compound than street tires though.
Old 03-02-2006, 08:44 PM
fabgmc4me's Avatar
I run the same psi at the track as on the street. 35PSI. I have a 35 series 18" tire, so I can't afford to drop the pressure to much. Lower PSI wouldn't really help me much because of the small stiff sidewall.
Old 03-02-2006, 11:45 PM
Moderator
nhra-trans-am's Avatar
i put mine at 35
Old 03-03-2006, 12:07 AM
Board Certified Idiot
Z2K_MrJ's Avatar
Heated Tires with 20 PSI
Old 03-03-2006, 10:35 AM
carado1984's Avatar
295/35/18 bfg comptas.. 35 psi here
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
25 in my shitty sumitomos
Old 03-03-2006, 04:36 PM
TAbeba's Avatar
same here 35psI w/18" tires
