shift points with hpp3 and rev limiter
Hey guys got the converter in and I am hiting the limiter a little.I have the HPP3 set at +2 from 1 to 2,+ 3 from 2 to 3,+ 4 from 3 to 4.Limiter is set at 6300.Should I put the limiter up higher? Mods in sig.
Location: Live Oak, FL - in the woods where the creatures lurk.
Re: shift points with hpp3 and rev limiter
What gearing do you have? I have the 2.73 and an ST3500. I had to do a lot of Autotap runs w/rpm vs current gear to find out what the trans/engine was doing. At WOT (from a standing start) I had to move the rev limiter to 6300, and set the 1-2 shift points to +3 for street radials. The best setup -in my case- would be to adjust the rpm/mph with LS1-Edit, but I've managed to shift things around with the HPP3 somewhat.
When the computer registers a certain MPH at a certain RPM, it will make that 1-2 shift.
