Trunk latch isn't opening right
Old 03-03-2006, 07:05 PM
pHEnomIC's Avatar
Default Trunk latch isn't opening right
I am having trunk latch problems. IT is weird. I know the keyfob takes two pushes to get the trunk to pop. Well, now, It makes me hit is twice for the trunk to pop up just a little bit. Then i have to push it again twice while giving upwards force on the spoiler or hatch. It gets to be a problem when other people have to open the trunk or the car is running and you want to pop it. (Turns into a two person job, one to hit button, one to push upwards.)
Anyone ever have this problem and how did you fix it?
Old 03-03-2006, 07:11 PM
hondo's Avatar
www.installuniversity.com has an article on how to fix it, I think you add a spring to the latch. My car does it too,pretty common. I need to fix it soon.
Old 03-03-2006, 08:30 PM
9silverbird8's Avatar
piggyback a 2 1/2 inch long 5/8 spring onto the factory spring on the latch mechanism....problem solved.
Old 03-03-2006, 10:00 PM
pHEnomIC's Avatar
Sweet, I was thinking about doing that myself, nice to know what size works though so I dont have to trial and error.
Old 03-04-2006, 12:31 PM
pHEnomIC's Avatar
That took a total of 2 secs to fix, Thx guys. Just unscred the bump stops a bit and it works perfect.
Old 03-05-2006, 09:41 AM
Moderator
davered00ss's Avatar
Yup, what he said.
Old 03-05-2006, 03:49 PM
Danny2tek's Avatar
works like a champ
Old 03-05-2006, 03:54 PM
prostock_bigblock's Avatar
have exactly same problem and I was pissed when i am alone . sprayed WD40 and worked great.
Old 03-05-2006, 03:57 PM
StangEaterSS's Avatar
i just piggy backed that exact spring on mine, still didn't fix it. it pops up like 1" or so and falls back down. wonder if the struts on the hatch are go'n bad? maybe they are too weak.
Old 03-06-2006, 12:15 AM
2002_Z28_Six_Speed's Avatar
Greased mine with wheel bearing grease and now it works normally.
Old 03-09-2006, 06:58 PM
Steve74-02's Avatar
just added a spring to mine. now it works great. thanks
