L98, = Lt1
Moderator
Originally Posted by 2000SLPZ28
is it possiable to put LT1 parts, such as heads, cam, and intake manifold, on a L98 motor. i dont have a L98, or a LT1, but i would just like to know.
Heads no, LT1s are reversed cooled. But L98s are Gen I SBCs, they have way more head options than LT1s do and you coan get some killer stuff for them. Cam, I belive you can get it to work, people run LT4 Hot cams in them. The Intake manifolds can be converted towork and a lot of people do
Originally Posted by whynot
find some vortec heads, and use the lt1 intake.
Yeah, the dowel pins are different lengths for the early optis versus the late lt1 opti's. Just use the dowel that came out of your original cam. I don't think the hole for the dowel are different depths, it's just the dowel length. Lt1 intakes will work, you just have to modify them to have coolant crossovers for the l98's.
