Post your LT1/LT4 Ported heads Flow #'s
Old 03-04-2006, 05:42 PM
formula355LT1's Avatar
Post Post your LT1/LT4 Ported heads Flow #'s
What do your LT1 or LT4 ported heads flow, and who ported them? My Speed Inc. RGR Stage2 LT1 heads flow:
INTAKE-EXAUST cfm
200:129-108
300:183-154
400:240-163
500:253-191
550:258-193
600:269-195
Old 03-04-2006, 08:14 PM
94greencamaro's Avatar
Ill post em in another month when i get my heads/intake back from AI Good topic though. I want to see these numbers too.
Old 03-04-2006, 09:06 PM
slagger's Avatar
hey 94green what set up you get on your heads?
i'm going with the 180 cc and roller
Old 03-04-2006, 11:31 PM
I got the 190cc full port with a custom grind roller plus i added Ferrea 6000 series valve upgrades. Add a ported intake to this and that is my top end setup.
They are going to have to feed an air hungry 383.
They advertise:
200 146/115
300 202/153
400 244/172
500 268/187
550 274/190
600 275/193
Ill get a big ****** boner the day i see them arrive to my house in the mail. **** im gettin one just talkin about it.
Old 03-05-2006, 12:08 AM
Cammed95Z28's Avatar
Intake: (2.02)
.100-------61.9
.200-------89.1
.300-------173.8
.400-------220
.500-------253.6
.550-------264.3
.600-------273.9
Exhaust: (1.55)
.100-------58.3
.200-------115.3
.300-------147.1
.400-------174.00
.500-------181.8
.550-------185.5
.600-------185.9
Port Pros Heads, Ferrea Valves, $1,400, like 2 years ago
Old 03-05-2006, 09:55 AM
zigroid's Avatar
.200 132/108
.300 195/142
.400 239/165
.500 268/179
.550 272/183
.600 272/188
LE3 heads done nearly 2 years ago. 2.0/1.56 valves
Old 03-05-2006, 10:15 AM
Chopstix's Avatar
GTP Stage 2 $1600
LT1 castings
2.02/1.55
185cc intake runner
Flowed by Brodix
Intake
.200=131.6/44
.300=188.4/63
.400=233.3/78
.500=262.6/87.8
.600=263.2/88
.650=256.6/85.8
.700=256.0/85.6
Exhaust
.200=109.5/34
.300=148.1/46
.400=175.5/54.5
.500=193.2/60
.600=202.8/63
.650=204.4/63.5
.700=206.1/64
Last edited by Chopstix; 03-05-2006 at 10:05 PM. Reason: added price and intake volume
Old 03-05-2006, 10:50 AM
TwoFast4Lv's Avatar
Modified STOCK LT1 castings Before final assembly and Valve job. This set of LE-X heads went together with new undercut valves 2.055/1.57 and had an Intake runner volume of 210cc. Lloyd figured they would pick up another 5+ after the VJ but I did not have a Local bench to test them
.100 63
.200 125/109
.300 179/148
.400 232/173
.500 265/189
.550 274/192
.600 283/196
.650 285/201
.700 287
They make very clean power to 7,000 on a 380CI.
Then again Flow numbers really do not mean much. It is more about port shape and volume Lets face it there is almost NO way to flow a head at the speed an Engine sucks air through
flyinZ's Avatar
LT1 castings, 2.00/1.56 Ferrea valves
Lift Intake Exhaust
.200 158 119
.250 187 138
.300 212 156
.350 236 169
.400 253 180
.450 268 189
.500 268 194
.550 N/A 196
.600 N/A 199
.650 N/A 199
Old 03-05-2006, 11:12 AM
ls1charged's Avatar
great idea for a thread i needed this, when u guys post your #'s can u make sure to tell where and who did them cause i want to get my heads done and im trying to figure out the best place to go, so far the ones i like the best are from MR. Elliot. thanks
Old 03-05-2006, 11:13 AM
slick1851's Avatar
Can we also include prices in this?
Old 03-05-2006, 03:06 PM
I went with AI for one reason. Although AI and LE have similar flow numbers, AI achieves this while porting the head almost 20cc less than LE has to to get the same numbers. This means more velocity, since the chamber will be packed tighter, which in turn means more power. Flow numbers arent everything. AI customer service is ****** sweet too.
Old 03-05-2006, 04:28 PM
ls1charged's Avatar
awesome, i will definatly check in to them.
Old 03-05-2006, 08:44 PM
wicked_95z's Avatar
.300 201/140
.400 246/167
.500 283/184
.500 294/190
.600 302/194
.650 303/197
Old 03-05-2006, 11:14 PM
TwoFast4Lv's Avatar
the problem with doing this on a Stroker motor is it NEEDS the extra 20cc's
Old 03-06-2006, 09:08 AM
roughneck427's Avatar
LIFT: INTAKE: EXHAUST: PERCENT:
.200 138 115 83.3
.300 182 151 82.9
.400 224 172 76.7
.500 255 186 73.0
.550 264 195 73.8
.600 270 199 73.7
Work done at Airflow Performance Engineering
Old 03-06-2006, 09:19 AM
blkchevyz's Avatar
.200 142.5
.300 198.9
.400 235.2
.500 268.6
.550 276.0
.600 280.4
.650 282.8
.700 282.2
stock lt1 2 inch valve
Old 03-06-2006, 09:49 AM
ls1charged's Avatar
Originally Posted by blkchevyz
.100 71.5
.200 142.5
.300 198.9
.400 235.2
.500 268.6
.550 276.0
.600 280.4
.650 282.8
.700 282.2
nice #'s, who did the work?
Old 03-06-2006, 10:00 AM
blkchevyz's Avatar
http://www.cylinderheadspecialties.com/
did a hell of a job, and was fast
Old 03-06-2006, 11:05 AM
slow96z's Avatar
Stock LT1 Castings w/ stock valves
.200 135/100
.300 189/128
.400 231/154
.500 255/180
.600 270/190
.700 279/ n/a
The Head Shop in Houston
Quick Reply: Post your LT1/LT4 Ported heads Flow #'s
