Tire size, what u running
Wanting to put some big rear tires on my WS6. I have the stock wheels 17X9.5 and would like to run something bigger than the stock 275/40/17 tires. What would you guys suggest. I will put a spacer on if I need to, but I dont want to but wider wheels I just want some more traction. Any input would be great.
your pretty much maxed out on tire size......read the sticky about 315's do not fit on 9.5 inch wheels....ihave 275/40/17 on front and 315/35/17 on the bak with 11"wheels
285/40/18 on the WS6. Stumbled into a limited private run of Michelin Pilot Sports in this size. No rubs or issues.
Otherwise I have been running 275/40/18 P-Sports's because when you jump up to the 285 (40 series 18") there are only 3 choices, Pirelli, Toyo, and Bridgestone.
One thing worth noting at least in the 40 series 18" tire. When you go up to the 285 from a 275, the sidewall transition seems to be more rounded transitioning to the tread (not squared off as much). I noticed this big time on the Toyo Proxes T1 285's and even so on the 285 P-Sports. I have not looked at the newer Toyo's T1R or T1S.
