Thoes that have installed a used clutch
Old 03-04-2006, 09:04 PM
DONAIMIAN's Avatar
Default Thoes that have installed a used clutch
Long story short, I have a friend that bought an aluminum spec stage 3 to go along with his new motor, then decided to go in another direction (C5).
That being said, I bought the clutch, has right at or less than 700 miles, Do I need to get the inside of the preasure plate resurfaced before it goes in. Its already going to the machine shop to be balanced anyways, and the aluminum flywheel that I have is getting a new friction surface. So I was just wondering how you did it.
Old 03-05-2006, 11:11 PM
SSmokin 01's Avatar
I don't see why it would need to be.
Old 03-05-2006, 11:18 PM
LS1powerhouse02's Avatar
no it doesn't. Just get the clutch and flywheel balanced like you are doing and you will be fine!
