what does it mean when my heater performance bank2 sensor 1 has a trouble code?
Re: what does it mean when my heater performance bank2 sensor 1 has a trouble code?
the heating filement is probobly bad
in your O2 sensor and you need to replace it.
if the response time of an O2 sensor is determined to be too slow the PCM will store a
DTC that indicates degraded O2 performance.
the O2sensors must be at least 600 degrees F
to run properly,they use a heater to get there quicker and stay there for opptomum performance.
hope this helps <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
thanx cueball, i got under the car and found the o2 sensor plug lying on my header melting away <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> i pulled it off and the wires are still good just had to seperate them and tape up so they do not ground out , so know to go see if it works!
no problem <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
just ask if you need any thing else <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
my service engine light was coming on and got this code from my atap po155 h02s heater performance bank 2 sensor 1 ? thanx for any info! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
