low oil light is on
low oil light is on
low oil light is on so i checked my oil and it was low but i just change
my oil 1000mi ago so why would it lose oil so fast maybe the cam?
let me know
thanks
let me know
thanks
No it's not cause of the cam, your burning or leaking oil somewhere. Time to figure out what it is. Could be a bunch of things, valve seals, piston rings, valve cover gaskets leaking, oil pan gasket.
First is it smoking start up or smoking on acceleration or deceleration? Plugs clean? How low was it? Correct me if i'm wrong but you'd have to be pretty low for the dummy light to come on don't you? I know our TA burns the normal quart between changes and i've never seen the dummy light come on.
Originally Posted by Sgt. Spuds
What do LT1's take? Sorry for the hijack.
Shirley Temple Drinker
No I have not...
I have never done it, and got the info I need pretty much. Instead of paying some grease ball 60 bucks I told myself that I am gonna just do it myself. Going to use mobil 1 10w30 and a acdelco filter... Gonna do it over spring brake.
5 qts in the lt1 with the standard filter brings you right up to the full line on the dipstick if you use the longer truck filter, 5 qts should bring you half way between the add and full line
