Can I use a Ram Billet Flywheel w/ 12" CF DF
Just as the title says. I have a Ram billet flywheel already and was just wondering if it'll work with a 12" CF DF clutch. I know some flywheels will only work with an 11" clutch. I'm just checking to make sure this Ram flywheel isn't an 11" only type. If anyone knows whether or not this Ram flywheel will work, please let me know. Thanks!!
If you can bolt up the factory clutch then you should be able to use the 12" Dual Friction?
You can call our tech line also to get the bolt pattern specs. (800) 932-5882.
Thank you,
Will Baty
Centerforce Clutches
Thank you,
Will Baty
