Cats, o2 Sims, or o2 delete from PCM
Ok, I'm wanting to do the full ehaust at once, (headers, Y, cat back) so I have a few Q's that may be stupid, but I have to ask!
If I get an ORY then there are know cats, so do I buy rear o2 Sims or have the rear o2 deleted from the PCM? Or both?
If I choose to use cats, due I still need the o2 Sims?
One last thing, I'm installing a cam at the end of the month and will have the PCM tuned then, even though I won't have the exhaust done can I just have them delete the rear o2's at that time?
Thanx any help would be great!
installing the headers , y-pipe , and a catback with no cats will appear an SES light , which wont harm your performance at all . once u do your cam , after that do the tune and delete the codes. anyways , if you r removing your cats try ditching the EGR and Air because they become useless if you r doing the ispection with no cats .
here u can find block of plates for Air and EGR , http://www.ls1speed.com/catagory.cfm?catagory=Exhaust
I blocked them because after my headers install I started hearing a ticking noise thats looks like a leaking sound .
Yeah just get the ory and leave the rear O2s unplugged untill you get your cam in, i drove mine around for a couple of weeks with the ses light on and it didnt hurt anything. just dont drive around with the cam in without a tune. and definitly remove your egr or air system.
