Check out this flywheel
Old 03-05-2006, 03:24 PM
UltraZLS1's Avatar
Default Check out this flywheel
http://cgi.ebay.com/ebaymotors/New-L...QQcmdZViewItem
What do you guys think?
Would it work with a ram powergrip/spec 3/centerforce df clutch?
Anyone use them or know anyone that has used them?
Old 03-05-2006, 03:51 PM
Moderator
davered00ss's Avatar
I would avoid that one. Go with a known name, so you know what you are getting. I have the SPEC Stage 3F w/ SPEC Billet steel flywheel. I love it and have had no problems. The flywheel wan something like $250-$300
Old 03-05-2006, 04:26 PM
oange ss's Avatar
i have one of their older stock lightened ones i think it weighs 23 lbs
Old 03-05-2006, 06:01 PM
TroubledWine3's Avatar
I bought that directly from the guys at AMS...I'm installing it with my SPEC 3 with a new master and slave on the 10th.
Those guys aren't a sponsor but they also aren't Advance Auto...they build race and drag cars for a living. I think it will be a quality piece.
Old 03-05-2006, 06:28 PM
2002SilverWS-6's Avatar
I just bought the 23lb one and my buddy also has the 23lb one with a ram power grip hd installed in his car. No problems for him. I'm waiting to install in mine with the same ram clutch.
If it makes you feel any better they are a Sponsor on www.ls2.com.
Seems pretty reputable to me.
Old 03-05-2006, 06:44 PM
Starz T/A 17's Avatar
Id avoid that go with a name brand especially with something as major as a flywheel
Old 03-05-2006, 07:03 PM
Galen's Avatar
AMS is local and located in Bossier City up in north La. They are known locally as Kittlers Automotive Machine Shop. While I have heard some good things about them, I have also heard bad things...depending on who is working for them at that time. All that being said, when it came time for me to purchase a new flywheel (yesterday), I went with a Textralia setup. I figure this is a job I really don't want to do multiple times, so it is not worth the risk of using cheap parts.
Galen
Old 03-05-2006, 07:18 PM
Their flywheels are SFI approved.
Old 03-05-2006, 07:50 PM
Rescue Ranger's Avatar
They are SFI approved, and are a sponsor on other sites.. thats gotta say something. I'd go for it man
Old 03-06-2006, 08:37 AM
TransSlam's Avatar
i put one in with my centerforce and it works great, they make a real nice product and was at my doorstep in 1 day. The guys over there are real nice and will help you in any way they can. just give them a call and you will see what i am talking about. I bought the one that was 2lbs lighter than stock, works great for me
Old 03-06-2006, 09:58 AM
UltraZLS1's Avatar
How do you get a hold of the slightly lighter one instead of the 18 lb?
I would rather have one that is over 20lbs, for driveability reasons.
I feel a lot better since some of you guys have tried it with some aftermaret clutches.
TransSlam....is your centerforce the 12' dual friction version?....because I am wondering if this will work with a 12" disc. And I am considering that clutch.
thanks all
Old 03-06-2006, 12:36 PM
UltraZLS1's Avatar
Is your centerforce the newer 12 inch version?
Old 03-06-2006, 03:41 PM
MagikMan's Avatar
you don't need to use an ultra weight flywheel.... although it is rotating mass, the flywheel helps store torque in between shifts... so it's not the end of the world to not have a lightened one.... that's why I just went with the ls2 flywheel on my ls7 clutch :-\
Old 03-06-2006, 05:25 PM
DONAIMIAN's Avatar
I agree. For thoes with the 23lbs flywheels, thats not really worth the extra cost to me considering the stock piece already comes in at 24lbs. This flywheel has an aluminum surface, meaning it will wear faster than the Fidanza with the steel friction surface. Not to mention the Fidanza flywheel with the steel surface comes in at 12lbs compared to this one that comes in at 17.5lbs.
Old 03-06-2006, 06:50 PM
UltraZLS1's Avatar
They advertise it to be 3 lbs lighter than stock, and made entirely from steel.
Im not sure I want the one from the link now that I have went to there website and found the 3lb lighter than stock version. Some people complain about driveability with too light of a flywheel.
Extra cost? How does 150 shipped to your door sound?
I am not going to put a resurfaced stock flywheel on my car....have to worry about shimming....if they went too far....balancing etc etc.
IF this is a quality peice I would rather save 100-150 bucks and buy this one.
I dont see in the link where the 17.4lb has an aluminum surface? Supposed to be 4340 Steel.
Where did you see this at?
Old 03-12-2006, 03:08 PM
Beast96Z's Avatar
As Galen said, their a local shop here in town. I stay away from there unless I need a part that they don't have anything to do with, like head gaskets or bolts in a pinch. FWIW, they don't make these flywheels. There a mass produced product sold in quanity. AMS buys the cores and may surface and balance them. Kinda like the rods they sell. Basically Eagles, but they buy them blank, do minor machine work, and call it theirs. When it came to getting my flywheel I got a billet steel spec. You should also be aware of WHICH SFI rating it got. There are diffrent levels.
Old 03-12-2006, 04:22 PM
Can you tell about the different SFI ratings? They have a yellow sticker on their flywheel that says SFI approved Spec 1.1 B083083. Also these same #'s are scribed on the flywheel. I really don't know what the different ratings or levels as you stated so would you please let me know if it is an exceptable SFI rating.
Old 03-12-2006, 08:00 PM
AdReNoLiNjUnKiE's Avatar
I'd go for it it only weighs 18 lb.
Quick Reply: Check out this flywheel
