FI or Nos??
Old 03-05-2006, 03:26 PM
TA4EVR's Avatar
Default FI or Nos??
I'm looking to spend some money on my car. It has 134 thousand miles. I'm pretty sure a supercharger or a turbo would require fully going thru my internals and spending alot of money ontop of the supercharger or turbo. So would a 100 or 150 shot of NOS need alot of motor work to make it hold? Also how much money am I looking at for NOS. Please help
Old 03-05-2006, 04:18 PM
blind527's Avatar
NOS is a company, N2O is nitrous. A 150 shot on a stock car would be fine, a lot of guys do it. Depends on the miles, and the fuel system. FI is only good to about 6-8 PSI with stock internals. With 134k on the clock, I would go a 100-125 shot depending on the fuel system condition. You can also get cut off switches where if it senses a dangerous fuel condition, it shuts the nitrous off. You'll need colder running plugs as well.
Old 03-05-2006, 04:32 PM
TA4EVR's Avatar
Ok my bad, N20. How much am I looking at? For everything I need to run it on an A4. Most people use a WOT switch right? Not a botton like on the movies or what?? thanks for the help
Old 03-05-2006, 06:35 PM
Vendetta's Avatar
i was never a fan of the WOT switch. You'd be better off with a switch IMO. But yeah I'm more of a nitrous kind of guy even though my LT1 was blown.
Old 03-05-2006, 07:02 PM
RoAdRaGe912's Avatar
with the proper setup either is fine. if you use a momentary switch like in F&F then 100% make sure you use a window switch. i'd still use one with a WOT switch of course, but you can get yourself into trouble easier with a momentary and no other safety precautions.
just depends what you want. do you want to push a button when you want to spray or do you want to just spray when you go WOT??
Old 03-05-2006, 09:22 PM
TA4EVR's Avatar
I want to push a button but I have an A4 so where would I mount the switch? So if I go with N20 how much am I looking at? For the whole setup, kit, install (or should I install myself?) all the safety stuff, guages, everything, how much?? Also do you think my motor with 134 thousand miles on will be ok like that?
Old 03-05-2006, 10:07 PM
rbobryk20's Avatar
i have 153k and spray. As for switches i have an arming switch that then goes to a momentary that finally runs through a WOT switch before actually spraying nitrous. I have an A4 and lots of miles and i don't want to spray through the shifts thats why i have it wired this way. btw just buy a new fuel pump and u can spray up to 150.
Old 03-05-2006, 10:32 PM
TA4EVR's Avatar
Old 03-06-2006, 09:26 AM
blind527's Avatar
You have to give us a little bit more detail on what you want...wet or dry? Direct port?
It can range from 500-2000.
Old 03-06-2006, 09:32 AM
blkchevyz's Avatar
whats wrong with WOT switches?
Old 03-06-2006, 05:46 PM
TA4EVR's Avatar
i want whatever is safe and better on a well cared for, old motor. i dont want to upgrade to much and id like to stay under or around 1000 all inclusive if i could. so what am i looking at for that price?
Old 03-06-2006, 10:13 PM
hashtagBMW
Speed Density's Avatar
Max on that motor i think would be 75-100 with good compression.
Old 03-07-2006, 10:12 AM
SmokedOutZ28's Avatar
I spent $1400 shipped for a wet kit good up to 300hp with all the saftey switches and gadgets, including a purge, bottle warmer and a remote opener.
Old 03-07-2006, 05:40 PM
TA4EVR's Avatar
Smoked, where did you order from and what brand and specific kit was it? Thanks
Old 03-07-2006, 06:01 PM
j99fbody's Avatar
i got nos system on my car and just over 100k, works great motor has held up fine with 125 shot. I got about a $1000 in everything wich included nos dry system, bottle heater, msd window switch and autometer guage. And its not that hard to install
Old 03-07-2006, 06:33 PM
TA4EVR's Avatar
where did you get yours and what kind?
