Turbo guys what are the specs on your cams
do cams in TURBO cars really make a significant amount of power throughout the whole rpm range?
You take MM's car for example he made what 850 with the stocker. If he put a cam in would it be that much different?
It would help out alot on a build like his. He is making some serious power thru that.
The Stock Z06 is a great cam for FI, but when you start getting into his level of power, it maybe worth around 50+ across the powerband and can change when his power band starts and stops.
In a nut shell, yes. It would be worth it. Does he need too? Not really. He already makes sick amounts of power.
