back pressure?
back pressure?
i have the slp lm exhaust and i'm looking to get pacesetter lt's and ory. i know ls1's need a certain amount of back pressure and was wondering if i was going to get enough with the lt's and ory. if any of you guys have this setup let me know how it worked for you, thanks.
well i'm not totally concerned with being too loud. i don't ever have people in my car. my only concern is performance. i was just worried about if i needed enought back pressure
Personally, just get a good catted Y pipe. It shouldn't really affect performance, will make it sound better as well as better db level and will keep you legal, so it'll be easy to pass emissions.
Also I'd recommend reading the sticky's in this forum, it will give you an insight into exhaust systems. From a performance stand point back pressure is always bad.
Originally Posted by stangnightmare
would you go with a magnaflow muffler instead the the slp "nothing at all" muffler. i know you can just insert it in the existing system "magnamouth?"
Here is mine. Check it out. I also feel the LS1 runs better with a little back pressure...high flow cats would be plenty. As far as it being too loud There is no such thing!
https://ls1tech.com/forums/generation-iii-external-engine/462478-pics-completed-true-dual-over-axle-exhaust-w-edelbrock-lt-s.html
Originally Posted by orangeapeel
Zeus, I am curious to find out how good your system works without the H or X in the equation. Looks freaking clean though man!
are the tsp catted y's a pretty good setup with the coated pace lt's. i've been looking at them online and it seems like a pretty good deal at $700 for the whole setup.
i'm also with you zeus, the louder the better. i live on ft.hood and the mp's on post aren't going to give me too much about how loud my car is. zeus your car sound great, that's an awesome setup you have there .
Rasp sucks. The cheap way to get rid of it is to get cats. Expensive way is iron block.
And besides the Jaguar V12 was aluminium and it was designed in the 50's, also the Rover V8 which is derived from the Buick 215ci. Buick ceased production in the 50's and it was aluminium but TVR's don't suffer rasp.
Originally Posted by 02SS:ZEUS
I love it. When you really understand the principals behind the H or X pipe, you come to realize that it is not necessary in all true-dual setups. It would help in some set-ups, and not in others.
Would you mind expanding on 'what' setups [u]do[/]u and don't benefit from a mid pipe and explaining what the differences are between them, cheers
