can't get tranny back on
I'm currently on the last portion of my clutch swap and I'm pretty much stuck. The flywheel, pressure plate, and clutch (used centering tool) are all correctly installed. I'm attempting to reinstall the tranny and for some reason it stops at about 1/2 inch from the bell housing and will not move any further forward. I can't figure out what the problem is. The slave appears to be correctly installed, but at the same time it might be holding things up since I'm not sure what to look for. The splines on the input shaft are also correctly lined up. Any help on this would be great because I'm stumped on this.
I've had mine apart 3 times. Each time it took a good amount of muscle and swearing to get it to go back together. There's not much to the slave install, if you think it's right, it probably is right. How are you supporting the trans, are you bringing it in level/square to the engine? I was under the car with the trans on a transjack, the front of the car was high, so I had to keep raising the jack as I moved forward. At some point I got it close enough to start the bolts and pull it the rest of the way on, just be carefull of stripping the threads if you aren't seated deep enough.
Good luck.
Good luck.
It takes some time and patience. You have to make sure the splines line up correctly and that it is lined up perfectly. A few bolts with take some weight off your arms/jack. You just have to play with it untill you get it lined up perfectly, and then push it in.
I don't have a trans jack, so I'm just using a floor jack as best I can. I'm thinking the best thing to do is to back the whole tranny out and down then make another attempt with better alignment. Thanks for the advice guys, hopefully I can get this done soon.
I just finished my clutch last night and i had the same problem. My problem ended up beeing my pilot bearing was on backwards. Another thing, make sure the aliment tool goes in and out easy with out having to push or pull on it.
Let me know if you need any other help.
-Miguel
Had the same problem with mine. Fought with it a few hours a day for two days. Then a friend came by and said just start the bolts and tighten them slightly in a criss cross pattern and it went straight in. As it turned out it had been lined up right the whole time I was just scared that the bellhousing would strip out. Best of luck I know how you must be feeling.
I'll take a look at the pilot bearing as well as that might be the issue. As for the bolts, the tranny is just far enough away that I can't get any of the bolts threaded.
just take your time and double even triple check everything! keep turning the tailshaft and pushing at the same time try putting the tranny in several different positions and it should eventually let you get a couple bolts in to start it.
currently in the same situation, just to clarify, which way is the pilot bearing supposed to go in? when i bought it the guy at the dealership said the more closed end went out, which made sense as its slightly funnel shaped
Ditto
WHICH WAY TOWARDS THE MOTOR?
One end is 'open' and the other end is rounded off, closed, and blunt. HELP!! It's dark out, getting cold, and my car is in a million pieces!
talked to a tech up at the local dealer and he seems to think the blunt closed end goes towards the motor, it only goes on the input shaft one way. mines already installed and halfway put back together but if you havent put it in yet then try it on the tranny input shaft and that'll tell you.
as for me / takin apart again tomorrow
Have fun!
