02 signal wire
!Dial-up Director
Re: 02 signal wire
The siganl is out of range, over 1.0mv. The light never moves, just stays pegged rich.
#69 is for the 99s, my 98 is supposed to be #47 on the blue connector.
#47 is prpl/white and that is the one I have spilced. But there is a high ( purple ) and low (tan) signal wire, I wonder which one is the right one.
Justin
Justin
Re: 02 signal wire
sorry about that,i missed the "98"
you want the purple/white wire the "signal wire"
the tan "low wire" is the voltage output
approx. 5V.
is your pcm going in to closed loop,
i know when you first start your car it is in
open loop and it will do that it is showing full rich untill it warms up and goes into closed loop
how is your gauge hooked up,some times if it is not hooked up to a good ground it could do that
good luck!
approx. 5V.
good luck!
!Dial-up Director
02 signal wire
I am hooking an air/fuel gauge and I need to know the correct wite to splice for the O2 sensor signal. I tried splicing the purple/white wire but it reads to high, should I splice the tan/white wire? I figure that one will read to low. What is the correct wire for a 98?
wire that I spliced
Thanks,
Justin
wire that I spliced
Thanks,
Justin
Re: 02 signal wire
i belive it is the #69 wire comeing out of the pcm
on connector 1-the blue one
it is the purple/white wire
the other wires wont work right
i am at work, i will check to be sure as soon as i can
what do you mean high?
!Dial-up Director
Re: 02 signal wire
Qball thanks I got it fixed. I am almost embaressed to say what it was. I was origianlly going to splice the wire right by the o2sensor but ended up splicing on the harness b/c it was easier. Forgot to plug the 02 back in.
