porting intake manifold to match throttle body
HELP!!! porting intake manifold to match throttle body
ok so i got a stock throttle body for lt1 ported to 54mm, do i need to port out the intake manifold holes as well? (im assuming yes) how do i go about doing that, do i need to take the hole thing off cause im sure there cant be a bunch of debris in the manifold. any help or special instructions are appreciated.
Originally Posted by White_LightningZ
No, stock is 48mm
what i did to get my 58 to work was stick the gasket on the intake, mark it so you know what to remove, then go to town with a dremel.
Believe it or not, the TB change will not give you **** on a Stock LT1. There are 500ci, 500hp Chevy crate engines with 48mm stock LT1 TB's on them. I have seen before and after Dynos on a TB change, and 1hp was the gain. 1hp for $300, bad investment. Don't waste the cash....
"thats funny we did that on my friends car and gained 8-10 all the way up the rpm band"
Your engine is not stock, different heads and cam according to your siganture....
We put a 48, 52,and 58mm on a stock LT1, and gained 1hp on the dyno. Bad investment on a stock motor.
