Hoosier 335/35/17 drag radial
Old 03-06-2006, 07:02 PM
Z28_LT4's Avatar
Lightbulb Hoosier 335/35/17 drag radial
Has anybody tried these on 17x11's? I'm currently running the 315 nittos and am getting very little traction on street or track. I am tryin to decide between the 335 Hoosiers or buy two 16x8 wheels and buy 26x11.50x16 ET streets.
Opinions
Old 03-06-2006, 07:10 PM
LETHL_SS's Avatar
Not sure if the 335 hoosiers will fit. From what I have heard they are a little bigger than the BFG drags (which are HUGE) <---- I have these but they are pretty much useless at the track as well.... arent too bad for the street though.
Old 03-06-2006, 10:14 PM
Z28_LT4's Avatar
My Nittos are about half gone so when it comes time for tires I'll try a set of Hoosiers.
I wish somebody made a tire the same width as the 315 Nitto but about a inch taller.
I'm not sure what size that would be? mabey 325/35/17?
LETHL_SS your car is awesome!!! How did you make the picture with your screen name and car?
Old 03-17-2006, 08:20 AM
KCFormula's Avatar
I believe Hoosier is comming out w/ a 315 soon.
Old 03-17-2006, 09:05 AM
ls1mongrel's Avatar
You can get the MT 275/40/17 on the 17x11's IM running this now and they work good !
Old 03-18-2006, 02:21 PM
Z28_LT4's Avatar
How do the Mickey Thompsons 275/40/17 look on a 11" wheel?
ls1mongrel
I see you got a 1.67 60ft time. The best I could get with Nitto 315's was 2.0 If I floored it off the line I can spin them most of the way through second gear
Old 03-19-2006, 11:35 AM
Hardtop00SS's Avatar
I believe that MT is coming out with a 315/35/17 DR this summer
Old 03-19-2006, 06:56 PM
Cam02ss's Avatar
im running 315 nittos on 17x11s as well and dont like them. i wanted to run the 325 MT ET streets but dont know if that would work. LETHL...which BFG drags and what size are you referring to? i want to get something with a wicked stance.
Old 03-19-2006, 07:47 PM
LETHL_SS's Avatar
I have the 315/35/17 BFG drag radial.... any BFG runs on the larger side. FWIW, the 275 version of the BFG is almost as big as a 315 Nitto.
Hopefully Hoosier will come out with the 315 this summer. I'll have a pair on order immediately if they do.
Old 03-19-2006, 08:33 PM
Cam02ss's Avatar
so a pair of 315 BFG drag radials will look wider than the 315 nittos that i currently have on the car?
Old 03-19-2006, 08:36 PM
LETHL_SS's Avatar
Definately!
Old 03-20-2006, 10:36 AM
01z28a4's Avatar
im actually running 335-35-17 on my 01 z28. i have the 17 by 11's zr1's and no problem other that 1 spacer on each side
Old 03-20-2006, 02:55 PM
ls1mongrel's Avatar
Here is a pic with the 275/40/17 on 11" rims, I have yet to get a good pass on these tires at the track,I cut the 1.67 with the 16" mt dr, Ill be goin to the track soon and will post 60's.
Attached Thumbnails Hoosier 335/35/17 drag radial-mtpair1vj.jpg
Old 04-06-2006, 09:58 PM
DALLAS's Avatar
do you have more pics of these?
Old 04-07-2006, 01:34 PM
ls1mongrel's Avatar
Yeah here are a few !
Old 04-07-2006, 03:07 PM
DALLAS's Avatar
Thanks.
Old 04-07-2006, 03:08 PM
777's Avatar
Like 2" wider. BFG's are like a 325 and Nitto's are like a 285.
Old 04-07-2006, 03:36 PM
DALLAS's Avatar
How wide are the 315 bfg's compared to the 11.50 m/t et streets? which ones last longer on the street?
Quick Reply: Hoosier 335/35/17 drag radial
