Do LS1s burn synthetic more than conventional??
Old 03-07-2006, 03:08 PM
Luna's Avatar
Default Do LS1s burn synthetic more than conventional??
Hey guys, just as the title says, will it burn synthetic oil more than conventional oil? This is my first time running synthetic, its due for a change in about 1000 miles... I checked my oil today and it was pretty low, my car never consumed oil when I was still running conventional, so what gives?
BTW I am running Mobile One 10W-30
I used to run Quaker State High Mileage Formula 10W-40
Old 03-07-2006, 03:11 PM
anthonyz281999's Avatar
did u just switch to synthetic?? ive read that as engines get older things become loser and synthetic slips by parts easier cause it is so slick...so that could be something to think of
RoyO's Avatar
My car never showed a difference. The harder I drove it the more oil it burned. Usually 1.5-2qts per 3,000 miles.
Old 03-07-2006, 08:03 PM
Luna's Avatar
I did just switch to synthetic , but I also have just taken the winter tires off recently meaning I have been driving it alot harder. Maybe its the combination of the two
Old 03-07-2006, 08:05 PM
12Gauge's Avatar
My old motor never did burn more than half a quart every 3000 miles. However, this new one is gulping down a quart every 2k.
Old 03-07-2006, 10:54 PM
WsSickLs6's Avatar
my car only burns mobil 1...Doesn't matter which grade, it will always burn...
Old 03-07-2006, 11:04 PM
GTObsessor's Avatar
I run M1 5w-30 and my car doesn't burn a drop.
Old 03-07-2006, 11:09 PM
dragracer44life's Avatar
no matter wat oil u use i dont care, if u always hit the gas or drive like an ******* like me its always gonna burn some amount of it, depending on how hard u always hit the gas. i use valvoline 10w30 tough forumla ****, and it burns it, im always hitting the gas hard and downshifting rough so the rpms are always up...
Old 03-08-2006, 05:48 AM
Patman's Avatar
You're comparing two different viscosities here though, and I'll tell you right now that the thicker viscosity of the conventional oil you ran was the reason why you consumed less oil!
Switch to a synthetic 10w40 or 5w40 and you'll consume less oil than you do with M1 10w30.
Old 03-08-2006, 10:05 AM
Dal1as's Avatar
I drive my car pretty damn hard. Taking it to redline at least a few times a day, etc.
Mobil 1 synthetic 0w-40 mixed with 5w-30 and I can go over 4000 miles and not lose a drop. I think the viscosity of the oil and the varying engine tolerances have a lot to do with oil issues. Not to mention I still feel an overlooked issue with our cars is the loose fit of the lid and air filters not being noticed on many cars letting in contaminents in to the engine.
Old 03-08-2006, 10:29 AM
Mike02Z's Avatar
Until I joined this forum I always used M1 5W-30 in all my cars. My Z would lose about a qt every 2k miles. I then joined this forum and switched to the German Castrol Syntec 0W-30 and even after 4k miles I do not seem to lose any oil at all.
Old 03-09-2006, 06:48 AM
Judge Smales's Avatar
I was glad to hear you say that as I just switched my truck over to gold GC and will be putting it in the Camaro also. I have a nice stash of green GC for the Camaro!
Old 03-09-2006, 10:07 AM
Luna's Avatar
So should I go back to a 10w-40 M1 or try the 5w-40, I know patman is the resident oil ninja so hopefully he can enlighten me more
Old 03-09-2006, 04:14 PM
YoMommasTA's Avatar
my experiance has been using 5-30 the ls1 drinks it at about 1 qt every 1=2k miles.if i use 10-40 or 15-40 it uses very little.i think it runs better and has better fuel mileage using the lighter oil.
Old 03-09-2006, 07:38 PM
Toasty's Avatar
I've used only M1 5w-30, and lately it hasn't burned it up at all. However, my intake manifold had a HUGE coating of oil on it.
Old 03-09-2006, 11:41 PM
_JB_'s Avatar
I use 10w30 Moble 1 Synthetic, have not noticed any level drop on the dipstick.
Old 03-09-2006, 11:42 PM
Luna's Avatar
I think I am going to install the new style PCV valve as well as a small catch can soon
