T56 slave
Old 03-07-2006, 03:38 PM
SHINER's Avatar
Default T56 Slave question
let just say i waited to long to change my clutch and I think something happen to my slave. I heard a pop and the car was not running the same I look under the car and I looked where the clutch breather slot was and it was infested with fluid. I checked my resivoir and its still half full!? Does it ALL leak out or what when the slave gets "over extended"? Also Is the slave inside or outside the trans. on a T56? Anyone I got a slave from an '02?
Old 03-07-2006, 04:26 PM
SHINER's Avatar
anyone?...Bueller?
Old 03-07-2006, 04:44 PM
SHINER's Avatar
Default T56 slave
Old 03-07-2006, 04:45 PM
TAbeba's Avatar
come one anyone.... inside when i had to change mine it just dint want to go in gear, but when i drop the tranny all of tranny oil went on my hair (which is long and blonde) it was a b**** to come out, but anyways make sure thats what it is
Old 03-07-2006, 05:53 PM
SHINER's Avatar
Answer!!!
Old 03-07-2006, 06:18 PM
chadtx01's Avatar
The Slave is inside the tranny. I've had **** for luck when it comes to slave cylinders.
If the slave is leaking, you will eventually lose all the fluid and the clutch will lose all tension.
Old 03-07-2006, 07:45 PM
SHINER's Avatar
Tttttt
Old 03-07-2006, 08:58 PM
BBADWS6's Avatar
Just drop your tranny and put in a new slave and clutch. It is your slave thats causing all the problems, you need a newer one anyways.
Old 03-07-2006, 09:11 PM
slowpoke96z28's Avatar
damn. never hear dof an overextended slave cylinder. if that is what happend. id put a new slave on it and flush out the master and braided line. https://ls1tech.com/forums/manual-transmission-14/. you'll find more info here.
Old 03-07-2006, 09:43 PM
SHINER's Avatar
thanks guys...and girls
Old 03-07-2006, 09:45 PM
SHINER's Avatar
Ttttt
Old 03-07-2006, 10:10 PM
JackZ28's Avatar
The slave cylinder is housed in the bell housing, and is between the tranny and pressure plate. I don't know how you can "overextend" it, but I do know that leaking could be a sign of it heading South!!!
Old 03-07-2006, 10:15 PM
Ben R's Avatar
Get a slave cylinder from an 02 car when you replace the old one.
Old 03-07-2006, 11:41 PM
Josh McGrath's Avatar
Or do what I did and buy a RAYBESTOS to remove the GM hydro disease from my car.
GM hydros suck ***
