Tube that comes off the airbox
What function does the tube that comes off the airbox have? You know the one where if you install a lid you have to put a breather filter on? Thanks
Originally Posted by 2001NBMZ28
It provides air to the cats on startup while the air pump is running.
well the car is having trouble idling at start up...It stumbles down to around 300 rpms, then levels out.....Then when I give it some gas, the revs come down, but instead of holding around 800-1000, then drop down below 500, and the car almost stalls out......
Im scheduling a tune up soon, but its driving me nuts not being able to figure this out
Originally Posted by y2k_ta
Nothing at all. You can remove the air pump.
https://ls1tech.com/forums/showthrea...light=air+pump
