General Maintenance & Repairs - Ls1 gastank like lt1?
View Full Version : Ls1 gastank like lt1?
pHEnomIC
03-07-2006, 06:54 PM
I know that it is common fact that the lt1 gas tanks are sloped and the gas guage is inaccurate. Full on fuel is way past the full mark. Half mark is ~1/3 left of gas, etc.
I notice that my ls1 guage 02 model seems a bit more realistic. I keep getting nervous next to the 1/4 mark and i go to fill. I only squeze close to 12 gallons in. What is the actual fuel capicity and what mark should i start to find a gas station by?
97MysticZ
03-07-2006, 07:04 PM
If you have your owners manual it will tell your tank size in there- just look in the index for capacities and specifications. I have a 98 and the tank is 15.5 gallons, and I am almost positive that after '98 the tanks are bigger by a gallon or two.
pHEnomIC
03-07-2006, 07:20 PM
It says 16.8. I don't know if this is realistic thoguh. So is it safe to say that i can run the car pretty close to the empty and still have a gallon or two?
FrozenMonkey
03-07-2006, 07:24 PM
My check gauges light comes on a bit before the E and I can continue to drive for 40 or so miles (waaay past the E) before I even think about having to get gas.
Slow00ls1T/a
03-07-2006, 07:25 PM
I have run my car til past e and when i filled it filled to 16.9 gallons so it is pretty accurate sometimes then other time i will be past 3 and it will only fill 14 gallons
9silverbird8
03-07-2006, 07:33 PM
You can get pretty well past E before you actually run out of gas, I've done it a few times, but I make it a rule to myself to try not to go much further than 1/8 or so of a tank. I just dont wanna get caught with my pants down.
Also, if you do run out, isn't there a chance you can @&%$ up the injectors?
bww3588
03-07-2006, 07:40 PM
fuel pump will burn up.....rule of thumb. keep it above 1/4 tank.
ACW
03-08-2006, 03:18 AM
98 had the same size as 93-97. 99-02 was larger.
LT1 fuel tank (93-97) (metal, 15.5 gallons) = 10269093
LS1 fuel tank (98) (metal, 15.5 gallons) = 10293379
LS1 fuel tank (99-02) (plastic, 16.8 gallons) = 10422917
I would not go past 12-13 gallons unless you're totally desperate. If you average 25mpg, that would be about 300 miles.
Once you know your average mpg, just don't pay much attention to the gauge, watch the miles instead. Sometimes the gauge will even shift on uphill vs downhill.
