Which master cylinder for textralia
Old 03-08-2006, 09:34 AM
Jimmard's Avatar
Default Which master cylinder for textralia
So I ordered a textralia clutch because mine was going out and I plan on doing heads/cam possibly spray in the near future. I want to replace everything while I'm there so I am wondering which master cylinder to get. I am thinking of getting the Ram adjustable master, the mcleod adjustable master, or just getting the 02 master. Which should I get? Any opinions or experiences appreciated. Also wondering if they will even work with a textralia. Thanks.
James
Old 03-08-2006, 10:51 AM
Kleeborp the Moderator™
MeentSS02's Avatar
They were designed around the stock hydraulics, so I'd stick with that. I'm pretty sure RAM just takes a stock master and makes it adjustable, so that would probably work too.
Old 03-08-2006, 11:19 AM
67Ranger's Avatar
i used a new stocker, and mine works good.
Old 03-08-2006, 04:53 PM
Jimmard's Avatar
Well the Ram adjustable master is only 10 bucks more than a 02 GM master. I would think it'd be worth the extra money if it worked with the textralia, just making sure everything will work right. Thanks.
James
Old 03-08-2006, 05:03 PM
bowtieman81's Avatar
Talked with Pete at Textralia. They recommend stock master cylinder with their clutches.
Old 03-09-2006, 01:46 AM
BirdofPreyBandit's Avatar
So, Textralia recommends the stock master? Freakin' awesome! I was already going to spend money on an aftermarket one. My Textralia is on the way too...well, I'm waiting for them to get some in stock.
Old 03-10-2006, 07:21 AM
JakeY2KZ's Avatar
Just curious...I'm new to the whole M6 world and would like to know what the symptons are if your master is going out?
