Headlight motor
Headlight motor
Is there a fuse or a circuit breaker for the passenger side headlight motor somewhere? Mine quit functioning and (headlight works though) I am trying to diagnos it.
motor is prolly dead. light will still work fine. do you know if it still makes any noise when you turn the lights on? if so....the gear in the motor is stripped. (its plastic)
Originally Posted by taintedmeat
There is a fuse for each motor in the engine comparment fuse box.
Thanks
Originally Posted by 93transam
On the driver side right? Is there a schematic for the fuses like the fuse box to the left of the dash, or do I just have to go through and check them all?
Thanks
Thanks
