will LT1 brake lines work with LS1 calipers???
i have a set of steal braided brake lines for an LT1 but am upgrading to the LS1 front brake conversion.. will my lines work with these calipers... they seem the same.. so i figured someone has done it before.. thanks guys...
I agree the LT1 lines will work, but the second time around when I replaced my Earl's lines with Wilwood stainless lines I used the LS1 line. You can see the line bracket in chrome on the K-member, if you use the LT1 bracket just flip it to the other side and put it at a 45 degree angle and you will be fine. This only applies if your running a coilover up front. If you use the a strut style front then leave the brackets on the correct sides. I'm running the LS1 spindles and LS1 Wilwood big brake kit on my 96 WS6 and I chose the LS1 line in the end and it has worked fine.
yea. ive got the ls1 brackets and all. but like i said i have braided lines for an LT1 so i will just reuse my banjo bolts that are already in the caliper... thanks guys..
by the way.... nice setup 96silverram...
