Does porting the maf lean out a/f ratio?
Old 03-09-2006, 11:07 AM
ss1129's Avatar
Default Does porting the maf lean out a/f ratio?
The reason I ask it because Im on a stock tune and when I changed my plugs the other day they were mostly white. Meaning Im running lean if Im correct? Would this hamper performance or is it worth doing?
Old 03-09-2006, 01:48 PM
Bombguy99z28's Avatar
Short answer yes you will run lean, enough to cause problems is a maybe/most likely depending on you setup, for the long answer read this or search this forum
Old 03-09-2006, 02:28 PM
blkZ28spt's Avatar
Search.
Short answer: DO NOT TOUCH THE MAF.
If you think it is running off get it on a dyno and find out what the air-fuel ratio is, and if it is off go from there with some tuning.
Old 03-09-2006, 05:05 PM
ss1129's Avatar
thanks for the info.
Old 03-09-2006, 05:12 PM
BLK02TA's Avatar
What if you bought the car with a descreen MAF?
Old 03-09-2006, 11:03 PM
blkZ28spt's Avatar
Descreening alone isn't as risky as porting it. If that is all that was done I wouldn't worry about it.
