FAST intake does not want to sit flush?
Moderator
Installing my FAST intake. The intake does not want to set flush on the heads. One side at a time will fit down on the heads? Replaced the vallye bolts. I am replacing an LS6 intake.
Originally Posted by mike c.
is that a 78mm or 90mm intake? if it's a 90mm how did you get the ribed boot to fit over the th-body?
Moderator
The TR224 is a great cam. i would get the same cam if I had it to do over. Easy enough if I decide to change later. As for Heads, I have several on the mind. AFR's, PP 243 castings, PRC (texas speed) 243's or 5.3's. I want the AFR's but the price is up there.
