Suspension & Brakes - Changing shocks and springs...
View Full Version : Changing shocks and springs...
2001 White Ws6
03-11-2006, 12:34 PM
Got the pass. side shock and spring off but i can't get the top nut off the spring perch. I can't even budge the fucker without the shaft spinning.
How do i cut this bitch off...i have a dremel at my use but i can't even budge the nut so what would you do to cut this shit off.
HELP!!
02SS#406
03-11-2006, 01:22 PM
Are you getting rid of the Hotchkis springs? PM me if you are. I'm in DFW also, and may be interested.
musclehead
03-11-2006, 01:36 PM
You need to use an allen wrench on the top to hold the shaft in place, then try turning the nut with an open end wrench. It will be a slow process but should work, also hit the nut with some liquid wrench.
2001 White Ws6
03-11-2006, 03:02 PM
I'm taking out the G2 super springs and the hotchkis sprigns are going in with bilstein revalves.
2001 White Ws6
03-11-2006, 03:03 PM
It's the stock shock shaft so there's no place to use an allen wrench. It's a flattened tip but vise grips nor a crescent wrench will keep it from spinning.
