Idle/rpm Probs
Old 03-11-2006, 04:06 PM
travSS01's Avatar
Default Idle/rpm Probs
Every so when i depress the clutch the car's RPM stays at the same rate for 1-2 seconds then it gradually comes down also when this starts to happen idle speed is crazy... sometimes it will drop then raise 200-400 in rpms? it started doing it today and i just threw a code (dont know what it is yet) anyone had this prob? any ideas?
Old 03-11-2006, 04:13 PM
iamsickofitall's Avatar
run to autozone and get the code scanned, post it up and someone will be able to give you an almost definite answer
Old 03-11-2006, 04:42 PM
travSS01's Avatar
ok the code is PO122 which is something like throttle position sensor, low input?
Old 03-11-2006, 04:58 PM
travSS01's Avatar
what can i do to fix this problem
