Is the plastic necessary?
Is the plastic shield in front of the AC and radiator necessary, can I take that out completely when I carve out the bottom of the air filter housing to get more air flow?
Originally Posted by 2K2WS6TA
If you mean the piece that seems to scrape on the ground when go thru a dip, yes that is needed, if you take it off you'll be overheating on the highway
