Nitrous Oxide - Routing of nitrous lines
View Full Version : Routing of nitrous lines
carzman5678
03-12-2006, 07:12 PM
I have a 1994 Z28 and I just purchased a wet kit that will be spraying 100-125 shot. I am going to mount it where the spare tire was. I was wondering how I should go about runing the line for it. Does anyone have and pictures of how they routed their lines under the car so I can get a general idea? Or some pictures of their setup?
Thanks in advance.
Hennytime
03-12-2006, 08:35 PM
i ran my lines along the passenger doorsill, like where you might run wire for a stereo, behind that panel and through the firewall, im not sure if its different, but ive got a ls1 fbody myself
jerflash
03-12-2006, 09:26 PM
i did mine the same way
run the line inside the car along the passager doorsill and get a holesaw and drill a 3/4 hole just under the heaterbox
227Hawk
03-12-2006, 09:35 PM
Ran mine along the fuel lines. A -6 & A -4. :)
Hawk :devil:
slowpoke96z28
run it in the car, drill a 11/16" hole at the firewall near the PCM(remove the PCM when you drill) and bring the line up the right valve cover.
1MEANGTO
03-12-2006, 09:52 PM
I think i may rerun my lines through the car also. Now I have them run with the fuel and brake lines. but I drive my car in the winter so inside the car may be the way to go.
carzman5678
03-12-2006, 10:06 PM
Thanks for the replies. Any pictures? Also, where can I get some solenoid brackets?
Dragframe
03-13-2006, 12:10 AM
kit didn't come with any??? bummer
fstphx
03-13-2006, 05:52 PM
Dont drill the Firewall-
there is already a grommet there that the wiring harness passes through to the PCM- just poke a hole in the grommet and go run along side- works great-
Pick up some wire loom and stick your hose in that- looks like another bundle of wires heading from the firewall- sneaky sneaky :devil:
227Hawk
03-13-2006, 07:45 PM
Under car bound in with the fuel lines.
http://i24.photobucket.com/albums/c18/227HAWK/HPIM0407.jpg
Hawk
Also a Racetronix 'Hot-wire in the bundle. :devil:
Hawk :chug:
jerflash
03-13-2006, 10:26 PM
wow your car is clean man...nice
227Hawk
03-14-2006, 07:21 AM
:emb:
Thank you
Hawk
