Weiand Intake Install
I am installing an aluminum Weiand intake and noticed that there are 2 tapped holes in the back next to the MAP opening. Any body know if they are needed or should i just plug them? Also, the opening for the MAP sensor is way smaller than the stock one. Where can I get a MAP that will fit and work with my stock wiring.?
Thanx in advance for any help! DK
Originally Posted by Randy WS6
The map will fit the hole,and the other ones if there around 1/2" pipe thread its for your brake booster you can go to any parts store a get a brass barb pipe fitting to conect the brake booster hose to,and the smaller one is for extra vacuum.
Restricted User
I know what you meen, I used the black RTV the good stuff, It work like a charm. with no vavuum leak at all for over three years now . Just dont get any in the little hole on the map senser ,it will plug it up.
