Eibach Prokit guys.
Old 03-13-2006, 01:16 AM
99camarosupersport's Avatar
Default Eibach Prokit guys.
ok basically a new set of eibach prokit springs are 350ish from sears. is this ridicously overpriced, it seems kinda steep to me i am thinking about trying to find a used set or buying off ebay, but when i called eibach to check on pricing in mid january the salesman told me that they didnt have any at the time b/c they were in the process of redesigning them b/c of some problems they had or something he didnt tell me what or anything b/c he didnt know. basically what im asking is should i just get a used set or a pair off ebay for 200 or below or get the new designed ones for 350ish. also did they improve or sacrifice handling on stock shocks or any problems.... thanks.
Old 03-13-2006, 03:35 AM
jbuerke142's Avatar
I've got a new set on ebay for $250. According to my distributor $340 is retail, there's no way in hell I'd pay $350 for them.
Old 03-13-2006, 05:30 AM
EDS01SS's Avatar
yup 350 is the norm for that kit
Old 03-13-2006, 06:05 AM
nikeboy313's Avatar
i wouldnt lower the car with stock shocks.. the stock decarbons suck with the stock spring rates and when you lower the car its only going to get worse
Old 03-13-2006, 06:55 AM
^^ i see you had a 94 trans, by any chance are the ls1 shocks better any even more the ss than the z's.
Old 03-13-2006, 07:55 AM
Brandon Boomhauer's Avatar
I like my decarbon/prokit combo
though they are blown to **** now, it was nice for a few thousand.
Old 03-13-2006, 07:58 AM
nikeboy313's Avatar
i dont believe there is any difference in the shocks from LT1 vs LS1.. but i may be wrong
Old 03-13-2006, 08:57 AM
~JOSHUA's Avatar
The DeCrap shocks are the same, but the stock springs are different from LT1 & LS1. It probably had to do with the extra weight of the LT1's iron block.
Old 03-13-2006, 10:02 AM
lt1/ls1 prokits are different too.
I *think* the lt1 is progressive rate springs while the ls1 is a set rate..... someone in the suspension forum could probalby correct that if wrong.
Old 03-13-2006, 10:22 AM
Xsta Z 28's Avatar
I hate Eibach springs . . . too soft . . .
Old 03-13-2006, 12:00 PM
~JOSHUA's Avatar
100% correct. If I bought a Pro-kit and Bilsteins I'd buy the LT1 springs to go into my 2002. From research it seems that's what the pros say to use.
Old 03-13-2006, 12:09 PM
makes sense, reason i was looking at the prokit was i'm wanting a 1.5" drop nothing more really i just want to lessen the space between the wheel and fender well, without making it look like mtv pimped my ride.
Old 03-13-2006, 12:14 PM
Toasty's Avatar
^ That's exactly what it will do! Pics of mine in sig- stock shocks and prokit. Handles a hell of a lot better than stock, and doesn't look like its dropping frame either. A nice medium. When I upgrade the shocks, I'll be going with Strano revalved Bilstein's.
Quick Reply: Eibach Prokit guys.
