Built turbo 400 with lockup,SLP Loudmouth, LS6 intake,BBK throttle body, Black ZR1's
I thought I would post it here too because I would prefer local pickup.
Custom Turbo 400 reverse manual valve body with built in trans-brake and converter lockup capabilities built by Chuck at FLP. Converter started out as a Vigilante Multi-disc lock-up converter but has been converted by PTC to a non-lockup 5000 stall converter. Also comes with dipstick to fit an F-body and deep aluminum pan. Less than 15 passes. It also comes with the flywheel. This is everthing you need to bolt to your LS1 motor. I have cut a 1.37 60ft with this transmission. This is over a $3,300.00 setup. I also have all of the paperwork with this transmission.
Price:
$1,800.00
BBK 80mm throttle body with all of the sensors.
$225.00 plus shipping
SLP Loudmouth cat back exhaust system.
$250.00 plus shipping
LS6 Intake
$325.00 plus shipping(Sale Pending)
6 Black Zr1's with tires
I only have three centercaps in all
Four 17x9.5's
Two 17x11's
Two tires are Goodyear Eagle F1's(275/40/17) with 45% tread
Two tires are Kumho Ecsta Supra's(275/40/17) one is a little better than the other one. I would say 25% tread on the better one and about 20% tread on the other one.
There is no tread left on the 315's
$800.00 for all six wheels and tires (Local Pickup only)
Pics can be seen at:
http://community.webshots.com/album/548441867wgPhfq
I am located in Lufkin about 2 hours North of Houston.
thanks, Brandon
Price:
$1,800.00
LS6 Intake
Four 17x9.5's
Two 17x11's
thanks, Brandon
