Single digits and a 6 speed
Old 03-13-2006, 11:55 AM
blown2kss's Avatar
Default Single digits and a 6 speed
Any body in here break in to the 9's or better on a t-56. And if so was the trans built, or was it stock with just a clutch.
I need some inspiration on this topic, or I might have to go with an automatic.
Old 03-13-2006, 12:16 PM
buschman's Avatar
Plenty of Forced Induction guys have done this. I know Lingenfelter makes a Turbo package whose 6 speed was pulling consistant high 9s. You can also talk to MightyMouse. He's running solidly in the 9s with a T56. He told me he had a shop beef his T56 up a little. I think he said somewhere around $1500. It's a hell of a lot cheaper than your most basic auto setup. I'm sure there's a few 8 second manuals out there, but none come to mind. 9's is definitely acheivable though.
Best of luck,
Mike
Old 03-13-2006, 12:34 PM
DONAIMIAN's Avatar
Matt Harlan back in the day used one, when he went ~10.0
Alan Futural went into the 9's with a solid roller 346.
Old 03-13-2006, 01:22 PM
blown2kss's Avatar
does anybody know of someone in the low 9's
Old 03-13-2006, 06:27 PM
Frost's Avatar
I remember reading of an 8 second car.... but it was an lt1
Old 03-13-2006, 07:37 PM
DONAIMIAN's Avatar
Going that fast in a 6 speed your gona run into problems of the driver keeping up with the shifting, tearing through clutches, and a lot of other things. Not saying that it cant be done, just the people that go that fast go for something more reliable.
Old 03-13-2006, 08:28 PM
OutlawZ's Avatar
Taner on this site has been I believe in the 9.40's with his T56..... 399 ci LT1 motor with a lot of juice...... And there are a couple of others on this site alone that still row the gears to 9's...
AFAIK, there is no f-body that has gone 8's with a T56..... Might be a Viper that has done it but I can't be 100% sure...
Old 03-13-2006, 08:34 PM
Ryan02SS's Avatar
Aren't most of these single digit T56's car setup to be proshifted.
Old 03-13-2006, 09:28 PM
67Ranger's Avatar
i believe one of the shop cars in TX went mid 8's with a 6 speed. I believe it was fastech, which is now closed.
Old 03-13-2006, 09:29 PM
Camaroholic's Avatar
My car "should" go high 9's now (last year I was only .14 away, and have since dropped back to 4.30 gears and added a Wolfe rear drag bar). My tranny isn't what I'd consider "built". The only aftermarket mods are pro shifting 2, 3, and 4, and a steel 3-4 fork. About $350 worth of stuff. I've also removed the 5-6 gearset for weight reduction. It's certainly not a daily driver tho.
You can get billet mainshafts, not sure about input shafts though. I think Taner was or is doing the GForce gear set (which is stronger than the stock gear set, but more expensive).
Don't ya love "should go" statements? Only one way to find out. I'll hit the track... hopefully soon. Our local track sucks though (for fast cars), so I think I'm going to have to travel to do it.
Old 03-13-2006, 09:53 PM
NVR_SPDS's Avatar
I know a Viper running a T56 and IRS running set the world record for a 6 speed.
Old 03-13-2006, 11:36 PM
multiplicityZ's Avatar
this wasnt in a T56 car, but i have seen a video of a 5.0 stang with a 5 speed go 9 flat.
Old 03-14-2006, 12:36 AM
Shirley Temple Drinker
Sgt. Spuds's Avatar
I can't even get my ******* hands coordinated enought to go from the steering wheel to shifter fast enought in my slow *** 13 second car...
Old 03-14-2006, 11:50 AM
blown2kss's Avatar
t-56 rebuilds will rebuild the 6 speed with g force gears and a whole bunch of other goodes for 4k, it's either this or an unreliable 4l60e because nothing else will fit in a vette without 10k worth of fabrication.
Old 03-16-2006, 01:33 PM
blown2kss's Avatar
anyone else got some times for a single digit 6 speed lsx
Old 03-16-2006, 01:39 PM
mike c.'s Avatar
my car is a daily driver m6 and went 10.2's last year. this year on the new set up i'm hoping for 9.7's-9.8's. i still have power everything and close to stock weight.(for now)
Old 03-16-2006, 02:10 PM
blown2kss's Avatar
couple questions for you; is your trans built, what kind of clutch are you using, and what is you rear end ratio.
Old 03-16-2006, 02:41 PM
SScam68's Avatar
FMS did it, proshifted.
Old 03-16-2006, 03:54 PM
Rescue Ranger's Avatar
Good statement and I have to agree. I don't want to discourage you either, but damn I can only see a car that fast with a M6 being such a bitch! But I'm not speaking from experience or anything so i couldn't tell ya how it'd work out. All I know is that you'd have to shift so damn fast and breakage/clutches would definately add up quick.
Old 03-16-2006, 04:08 PM
blown2kss's Avatar
If I stick with the m6 I will have it built. rpm transmissions have built some good trannies, but the clutch will be the biggest concern after the rebuild. since it will be a street car either the clutch will have too much grip for the street, or not enough for the track. Or with t-56 rebuilds can do the whole trans with g-force gears that have held 1300 hp to the wheels. rpm's rebuild is about 2k, and t-56's rebuild is about 4k. But then again it still wouldn't be as consitant as an automatic.
Quick Reply: Single digits and a 6 speed
