water in back seat?
Old 03-14-2006, 08:21 AM
Trev_SS's Avatar
Default water in back seat?
after i wash my car i notice that there is alot of water in the bottom of the drivers side rear seat underneath it, i know that people on here have had this problem before, so i was just wondering where the drains are at in this car. thanks
Old 03-14-2006, 02:32 PM
Blown Ta's Avatar
do you have t-tops?
Old 03-14-2006, 02:42 PM
LS69TA's Avatar
Probably T-Tops. Mine leak if I spray alot of water directly on the seals.
Old 03-14-2006, 02:48 PM
spee's Avatar
I curious about this, too. I've had a lot of water collect under my rear seats. It doesn't happen every time I was the car, though. I have a hard top.
Edit: I forgot to add that it hasn't happened since replacing the driver door's hinges.
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
plugs in middle of floor where your feet sit....look underneath and you will see them...you can remove and replace them from under the car----possible one fell out or is not in securely...I routed the wire from my elec.cutout through the plug....
Old 03-14-2006, 03:01 PM
Charging TA's Avatar
Well I dont know about in the seat, but it was raining for a lot last summer and my back carpet got wet after moving the car... just the feet area though, so I guess I gotta do like NHRAMAN said and check for the plug (didnt think of it before).
Quick Reply: water in back seat?
