Gears & Axles - Speed Sensors on Strange 12-bolt
View Full Version : Speed Sensors on Strange 12-bolt
Predator
03-14-2006, 12:23 PM
I've been looking at my 12-bolt and wondering where the speed sensors plug in. This is a 4-channel fully assembled rear with backing plates and reluctor rings. I was wondering if I have to transfer these over from my 10-bolt? I thought the speed sensors plugged somewhere into the backing plates, but there is nowhere to plug into. Thanks.
Predator
03-14-2006, 03:04 PM
There's a hole in each backing plate, with a small tapped hole next to it, that I assume is where the speed sensor stuff installs. I also assume that I'll have to transfer the speed sensor stuff from the 10-bolt to the 12-bolt?? Anyone know? Thanks.
Predator
03-15-2006, 02:17 AM
Okay, I've been researching this, and even though the Strange 12-bolt is fully assembled, plug-and-play, you still need to transfer the speed sensors, for a 4-channel setup, to each backing plate.
Predator
03-15-2006, 02:18 AM
BTW, nothing like talking to yourself ;).
I'm not schizophrenic, I AM! :)
peterock98
03-20-2006, 03:42 PM
No I do it all the time :judge:
Predator
03-20-2006, 05:14 PM
You must work on your own car then too. :)
