Anyone running a trank trigger on their LT1?
If so what type of trigger did you use and what type of stand alone setup are you using for control? I am building my new 383 currently and want to go with a crank trigger system and would like to get your feedback on how you like your setup.
Thank you very much,
RJ
RJ
Originally Posted by Compstall
Mine came with a variation of one from the factory. It works fine.
a friend of mine that posts on here ran a crank trigger setup for a little bit because he couldn't chase down an ignition problem. i'm not sure what it was that he used, but i'll search for the thread or tell him to post up.
Thanks for the input guys, I would love to hear more about the ingnition problems.
Tony, do you have to run both the trigger and dizzy with the XFI? Why run both?
Originally Posted by Stefan D.
The big stuff utilizes a cam sensor also. I do not run an opti, I run MSD distributor that has been modified.
I've always been curious, for the guys who've run both batch and sequential injection, what are the pros and cons of each? I'm most interested in what people consider to be the "improvement", (if any), that sequential has over batch. And what are the limitations involved with using batch fire? I'm asking because I too plan on eventually ditching my Opti in favor of an aftermarket EFI setup, and wondering if the rather steep price difference between a "sequential capable" and a regular batch fire system is at all justified?
Originally Posted by Tony Shepherd
I am using a MSD 7" crank trigger and a MSD low profile crab style distributer. Using the FAST XFI as the management system with bank to bank (batch fire). Just purchased the stuff so I do not have any numbers yet.
Always wanted to do the crab style dist setup, would love to know if you can pull the crab out with out dropping the engine.
Stefan D.,
You stated you had your MSD distributor modified. I take it you had a cam sensor installed so you can run Sequential. If so, who modified it for you. i have a front mount MSD and would like to have a cam sensor installed.
BTW, another good reason to run sequential is when running large injectors to help with the idle quality. I have 160lbs. injectors on my 598 and want to run the sequential for that purpose. Other than that I'd run the batch since i't a drag car.
-Dave
-Dave
Originally Posted by ultra 94 z
I am also running big stuuf 3 in the process of instaling now it uses a ls1 pcm harness and they suplied the crank triger cam sensor and ls1 ignition coils
Originally Posted by atljar
Ive got one too. You can pull the distriubutor without dropping the engine, but the intake has to come out with it.
