How long do you guys wait for you car to warm up?
Old 03-15-2006, 05:58 PM
Justin00SS's Avatar
Default How long do you guys wait for you car to warm up?
I know my 92 camaro needed at least 10 min. to warm up and it would idle high until it did.
But that was an old iron block 305.
What about these new ls1s? How long do you guys wait before driving?
This is ofcourse after the car as set for hours letting the all the coolant and oil temp down to outside air temp. Like overnight.
Old 03-15-2006, 05:59 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Long enough for me to close to door, put my seatbelt on, tilt the wheel down, and put her in reveres... But thats just me.
Old 03-15-2006, 06:04 PM
Swang's Avatar
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
really...if its warm weather at all...and you take off...in like less than 5 itll be at operating temp. when its cold...id give it 10...
Old 03-15-2006, 06:06 PM
TheRedPhoenix's Avatar
Whenever the needle gets off the left side. I do it no matter what- 45degrees to 80.
Old 03-15-2006, 06:07 PM
Moderator
davered00ss's Avatar
30 sec or so.
Old 03-15-2006, 06:09 PM
john3daly's Avatar
It doesn't take but 30 seconds or so for the oil to get warm, after that, you're good. Just don't beat on it til it's at operating temp.
Old 03-15-2006, 06:31 PM
catfSSh's Avatar
the general rule is you can get in and go as long as you stay under 25mph for the 1st mile.
for my camaro i wait for it to get off the left side of the gauge like someone else said so at least the oil temp is registering on the gauge.
Old 03-15-2006, 07:44 PM
Justin00SS's Avatar
Thats what I've been doing. Thanks.
Old 03-15-2006, 08:27 PM
SladeX's Avatar
I wait a min before going, general rule is keep under half of redline and 1/4 to 1/2 throttle till its warm, its warm in around 5 mins of driving, 10 mins if its cold.
LS1 engines heat up VERY quickly compared to my old gen1 engine. When cold (40F or less), my 88 car will drive for as much as 20 mins before it reads a tick on the guage and isn't at normal operating temp till I've been driving for almost 25 mins.
Old 03-15-2006, 09:43 PM
RaNsOm's Avatar
about 30 seconds. The best way to warm a car up is to drive it right away, cautiously, and allow it to get to operating temperature.
Old 03-15-2006, 10:03 PM
Camaroz's Avatar
Turn the key, back out of the driveway, don't rev over 2K.
Old 03-15-2006, 10:56 PM
MdFormula350's Avatar
x2
Old 03-15-2006, 10:59 PM
DaGeneral's Avatar
I wait until its at operating temperature, I turn it on just before Im finished gathering my stuff in the morning, and as Im putting crap into it warms up. So maybe 5 minutes max.
Old 03-15-2006, 11:06 PM
black00TA's Avatar
most of the time i walk out and start it and let it run for about 10 minutes prior to me driving, but if im runnin late ill just hop in and go.
btw, my car makes crazy loud knocking noises over 2500rpm when barely off cold mark. and i dont like listening to that
Old 03-16-2006, 03:12 AM
Hoss Ghoul's Avatar
Keep in mind that if you're just letting the car sit to reach operating temp, you are ONLY warming the engine. Not the gear box, rear end, or brakes.
General rule is to let the idle settle a bit...30 seconds roughly, and then you can drive away, just don't rev the engine past 2500 until it reaches open loop operation. After that, flog away.
Old 03-16-2006, 04:45 AM
Patman's Avatar
I start it and go immediately, even when it's -15F (luckily this winter it hasn't even gotten below 10F here)
I just drive very gentle until the oil warms up. For instance, I keep the rpms below 1500 until the oil gets to 100F, then I still keep it below 2000 rpm until the oil hits 150F. I don't go full throttle until the oil gets over 180F.
Old 03-16-2006, 07:35 AM
Weezzer's Avatar
Originally Posted by john3daly
It doesn't take but 30 seconds or so for the oil to get warm...
Either you do not have a functional oil temperature gauge, or you have some kind of mechanical problem with your car.
If both of these previous parameters are summarily ruled as not applicable to your stated disposition, then the only other alternative remaining in your case is the following:
Your skills in defining the basics of heat and mass transfer are only fully eclipsed by your expertise and skill in the written English language (as is evidenced by your previous post) .
Old 03-16-2006, 08:59 AM
Mr Incredible's Avatar
That's what I do...from below zero to 100+.
Old 03-16-2006, 10:46 AM
Ryan02SS's Avatar
X2...
Old 03-16-2006, 02:29 PM
Black Z/28's Avatar
Pretty much the same here, except I don't back out of the garage/driveway- I pull straight out in first gear (I always back it in ).
